How to refresh connection between a UiPath project and Orchestrator
I’m working on a project. My sequence has the getappcredentials xaml. On orchestrator I’m changing the username continuously but it looks like my project and orchestrator are out of sync. Every time i run my project it gets the credentials from the previous one.
I’m even deleting the credential type from the assests and its able to grab.
@michaelamay0
I guess you stored credentials in Windows credential manager also. If yes then delete it from there and then try once.
Hi
Kindly check whether the orchestrator is connected to a right machine
And ensure that we are not using GET SECURE CREDENTIAL activity as it will take from your windows credential manager
If we want to take the value from orchestrator asset use GET CREDENTIAL activity
Cheers @michaelamay0
