Is it possible to refer to a range of Excel cells using structure reference (e.g., column names) in StudioX
I have created a table (using Format as Table). Then I can use Write Cell to put in a formula that uses the column names (e.g., What to Write =[@[PRICE]] * [@[QTY]]). It’s much easier to understand using structure references and also good when I’m not sure the number of rows or the column letter.
When I’m in Excel, if I want to refer to the cells in a column of that table, I can use a structure reference (e.g., [TOTAL]). How can I refer to the cells like that in UiPath StudioX? Currently, I have to use cell referencing in StudioX. For example, in the Copy/Paste Range activity, I want to refer to column names in the Source and Destination. The Advanced Editor looks like this SalesData.Sheet(“Sales”).Range(“E2:E3269”)). How can I tell it to use a structure reference?
Hello @kmac!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
  1. Always search first. It is the best way to quickly find your answer. Check out the image icon for that.
    Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
  2. Topic that contains most common solutions with example project files can be found here.
  3. Read our official documentation where you can find a lot of information and instructions about each of our products:
  4. Watch the videos on our official YouTube channel for more visual tutorials.
  5. Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
