How to read pdf data and write into csv with comma format or with column header
I have the assignment of pdf data into csv file, this is my mail id kumarvinod14@gmail.com.please it is emergency i am trying but i am facing this issue i didn’t get any solution and i didn’t get any clarification so could you please send me the program.
Thanks ,
Hi @vinod143
Use read pdf text with ocr and use generated datatable and then use write csv activity
Thanks
Ashwin.S
Dear AshwinS2,
I am New in UiPath …I am trying which you suggest …But I am not able to achieve now …
Plz can you share the program for it?
Thanks ,
Hi
May I know the issue you were facing on using this
Cheers @vinod143
