There is one use case that I have to use a macro-based excel file (.xlsm) to read and write the data with the help of the Uipath tool and which is working properly on excel application scope activity but not working on Workbook activity.
So the reason behind using workbook activity is that I have a process that I have to download multiple CSV files at a time from the SFTP server and after downloading all the files stored in one local folder and then we have to map that CSV file with one macro excels(.xlsm) file and then RPA generates an excel(.xlsm) file as an output for each file. But the condition is I have to execute all the files at the same time. So can anyone help me with how to make a logic using only one bot?
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
