Hi All,
I got error to assign result of Read Column using GSheet. Can you give example about that ?
Thank you
Hi All,
Thank you
Hi @asta_clover,
Provide more details to understand your area of exception.
Provide activity you are using or maybe screenshots.
@asta_clover, issue is with your variable.
Looks like data_column variable that you created is an array and the output of read column activity returns a different type of data type.
Try create a variable from Output text box using Control + K, then automatically variable with expected data type will be created in variables panel.
