I want to navigate on different fields of a webpage through TAB and then select the required element by pressing enter. Is there any way to do this?
Thanks!
Hey @harsh497,
Try using send hotkey activity and select TAB in the key parameter(dropdown list). you can indicate this activity to the webpage you want to automate.
let me know if you need more info.
Best Regards,
SP
