I am having a variable = “BU” , where the “BU” will contains 100+ different departments, I am thinking of designing 1 Flow Switch to handle 10 BU, then the rest link from the current Flow Switch A (10) to Flow Switch B (10) , is that possible ??
I am thinking of using 1x Flow Switch for each BU, basically it will capture the BU from the Excel, let say the Excel is showing “Tax 2 Sub Department” > it will go through Flow Switch 1 to check whether it is within that Flow Switch, if not, then it will go to Flow Switch 2 to check.
I see, must be “Default” then it only will link over from Flow Switch 1 to Flow Switch 2 ?? Cause I can see some others are showing “Case 2” / “Case3” … and so on
