When Trying to hit a View PDF button on a Web portal in loop the bot doesn’t hit the click event.
i am using in for loop for many PO’s so the click activity does not work…
When using a view PDF button on single Po it works.
already use.
simple change the selectors select as aaname
Can you share your workflow (simple screenshot would work)?
Have you tried to select the “View PDF Button” outside of the loop?
Not Working in For loop.
Keep this click activity within GET ACTIVE WINDOW activity being inside the loop
And enable simulate click property in the property panel of click activity
Cheers @ajay.tile
When you open the Selector Editor window and hit the Highlight button, is the right element highlighted?
Having you tried reloading the page, opening the Selector Editor window, and hit the Highlight button? Is the right element highlighted?
As @Palaniyappan mentioned, have you tried enabling the “Simulating Click” property?
Hi
Thanks for your continuous help.
I have explored all the options but they are not addressing my concerns
Can you please arrange a call with your experts
My email id is ajay.tilekar@ag-technologies.com
My contact number is +91-7021673621
Location is Mumbai , India
Preferred Language :1) Hindi , 2) English
Looking for timely support
