Hello Everyone,
How to highlight the first column with Color and I want to merge 4 column into one.
Thanks In Adance,
Niranjan
Hello Everyone,
Thanks In Adance,
Niranjan
Hi @niranjan.kummara ,
Use “Set Range Color” activity
Can you explain 2 request with example screen short that “merge 4 column”?
Thanks,
Rajkumar
@RajKumar_DC Thanks for your reply Raj, i just want to merge “Announcement sequence Code: AA22” to all the columns.
this is the header for the 4 columns.
niranjan
Kindly Check this workflow
Input
Output
Workflow
Code
(From row In dt.AsEnumerable
Let meg=row("Col1").ToString+row("Col2").ToString+row("Col3").ToString+row("Col4").ToString+row("Col5").ToString
Select dtOut.Rows.Add(meg.ToString)).CopyToDataTable
Thanks,
Rajkumar
@RajKumar_DC im getting document invalid error message. kindly share me with supporting files to open 07.xaml file.
