How to give timeout of 40 mins in integer bcz it's giving issue while running the code? Urgent plz help
cint(in_Config(“TimeoutUltraLongest”)) >> which has value as 2400000 in config excel
Giving below issue:
Hi @anjasing ,
It seems there is an additional space comming after "2400000 " .
You can use trim
cint(in_Config(“TimeoutUltraLongest”).ToString.trim)
Hello @anjasing ,
It would be better you can check the value of Cint(in_Config(“TimeoutUltraLongest”)) in debug mode or print it in a message box. Also check once in your config file, by mistake you have added any space after the value. If it’s there remove it using Trim.
Thank you so much :slight_smile:
