Hi @JustZaffan
Check this xaml adapth it to your excel
BlankProcess5 - Copy (7).zip (4.1 KB)
cheers
Here is the dummy data
Dummy Data.xlsx (9.4 KB)
The task is to find the row index for row containing β2022β, βI.Decβ and βLine12β
Can you try the following sample?
Sample20221208-9.zip (10.1 KB)
Did you happen to check the xaml i provided?
Are you facing any issues?
