HELLO EVERY ONE.
I AM HAVING AN ISSUE. I TRYING TO ENTER DATA FROM EXCEL FILE TO A WEBFORM. THE FLOW IS LIKE THIS:
THE WEB FORM IS OPENED AND AN EXCEL FILE ALSO
GETTING THE ROW VALUES OF EACH ROW AND TYPE INTO THE WEB FORM
WHEN SUBMIT ANOTHER PAGE APPEARS AND IN THE NEXT PAGE THERE ARE 2 LINKS I HAVE TO CLICK THE SECOND LINK.
ANOTHER PAGE COMES WHICH I HAVE TO SAVE AS PDF.
THE PROBLEM IN THIS TASK IS SOMETIMES THE NETWORK MAY BE SLOW OR IT TIMESOUT AND FOR THAT AFTER SUBMITTING THE LINKS DON’T COME.
SOMETIMES THE NEXT PAGE COMES WITHOUT CLICKING THE LINK.
AND WHEN THE SEND HOT KEY OF CTRL P WORK SOMETIMES THE PAGE IS NOT FULLY DISPLAYED IN PREVIEW. THUS SAVED AS A PARTIAL PORTION.
WHAT CAN I DO FOR THESE PROBLEMS?
THANK YOU.
Set the WaitForReady property to Complete in all the activities you are using, and for send hotkey, you can use a check app state activity in order to check if the element has charged completly
