Hey Everyone, the problem I am facing today is that I want to extract some data from a website.
I am using get text activity, but the problem is it is selecting the whole string but I want to extract some particular parts from the string.
Would you please help me out with this problem. I am attaching the screenshot for more clarity of my problem.
I want to extract “55283 ” and “Nierstein ” but it is extracting “55283 Mainz-Bingen (Kreis) - Nierstein”
Hi @Muhammad_Anas_Baloch
Number = Split(msg," “)(0)
Name = Split(msg,” “)(Split(msg,” ").count)
Hope this helps.
Hi @Muhammad_Anas_Baloch ,
From the Extracted Output, we can manipulate to get the required data :
Split(extractedValue).First //First Number Output
Split(extractedValue,"-").Last //Last value
The above is assumed that all the data format will be the same, if the separators are only space and not -
, for the second expression just remove the delimiter part.
Let us know what is the actual pattern and if the expression works for all the data that you have.
Gokul001
(Gokul Balaji)
April 6, 2023, 1:02pm
4
How about the Regular expression?
System.Text.RegularExpressions.Regex.Match(YourString,"^\d+").Tostring
System.Text.RegularExpressions.Regex.Match(YourString,"(?<=-\s)\S.*$").Tostring
Regards
Gokul
You can easily use Matches activity to compose a regular expression and use it extract what you want.
This Solution worked for me but in VB.net not in C#
This solution worked for me in C#.
Thanks for the info, i had same problem so I’ll try. Thank you so much!
system
(system)
Closed
April 10, 2023, 9:10am
11
