How to fix your Studio installation / Licensing issues
Hi @Partha_Maity
Even though I do not know your particular situation, I would suggest the Community Edition as your default option to use.
5 posts were split to a new topic: Studio silently fails to launch after fresh installation
Please check if either:
  • a process for Studio shows up in Task Manager
  • any sort of event is registered in Windows Event Viewer
A post was merged into an existing topic: Studio silently fails to launch after fresh installation
7 posts were split to a new topic: Studio Community installation progress gets stuck
hi @loginerror can you please tell me in step 3 where i have to write those commands.
because i try to write them in cmd prompt but its not working.
That’s correct, it should basically work like so:
You might have to run the Command Prompt with admin permissions. Otherwise, please share the error you are getting.
11 posts were split to a new topic: Locally unlicensed Studio Enterprise Edition cannot acquire a license from Orchestrator Community Edition. Please use Studio Community Edition
