How to fix 'AsEnumerable' is not a member of 'System.Data.DataRow' in UiPath?
Hi Team,
It isn’t System.Data.DataTable because it was solution that was showing up when I checked with google.
strTotalSum = requiredRow.AsEnumerable.Sum(Function (x) Convert.ToDouble(x(“Net Volume”).ToString.Trim)).ToString()
Hope the info is clear enough.
Thank you
add the namespace
system.data.datasetextensions
How?
They aren’t giving me any options
It is there already
Then i assume that bug is not yet fixed
Below thread will give you the idea.
That was a known issue which was supposed to be fixed earlier this year.
@loginerror @Pablito can comment on whether this was taken into consideration.
Funny thing is I’ve two projects in one it is working and in the other it isn’t working
They’re suggesting that I should uninstall studio and then reinstall it again
And that’s along process for because am not the admin of the machine I am using
yes that confirms bug is still there
Thanks for highlighting.
Regarding troubleshoot, I know it’s weird but
Just delete that activity and add a new one ro check
just simply closing the file completely and then trying to open can also handle this issue.
Also we can check the json foe the namespace part doe two process (working one and this one with error) to verify that are identical
The one that isn’t working has many namespaces compared to one that is working
Why are you applying AsEnumerable on a datarow and not the datatable?
Perfect @Charbel1
I wasn’t seeing that now it’s working super fine
No it makes a lot of sense that why google also didn’t know the answer
Thanks
No need!
Have a great day.
@Kakooza-Allan-Klaus
In the old version there is an issue, check below for your reference
But this was rectified in new versions
Hope this may help you
Thanks
we had a troubleshoot call and ee also confirmed on this topic, this issue is not yet resolved
Shiver weird solutions worked for us and along with that, you can also add that namespace in the Json. Just open the project.json in notepad and in the namespace section add the desired namespace
