and use this Regax i am get this URL below the screenshot
and after that merge the URL in one variable
and same variable write in add data row
below in the screenshot
The above regex is working, try this in try catch…
Exception as null
In the exception box just pass one assign.
yourstring = “NULL”
Hi
Can we extract this URL from matches activity and store it in a variable instead of assigned activity.
below in the image
i want to get this URL in one matches activity and store in one variable
You can get the url separately and after that concatenate both the values as one
Regards
Gokul
Hi Thanks for reply
but i am getting the both URL and after that merge in one variable
But when start the robot it is showing the error in add data row.
so i am asking about matches activity
Can you share the screen shot with the add data row properties?
And also have you checked with message box that all the values which you passed in add data row has returning some values?
Regards
Gokul
Hi
This is the add data row properties variable name.
and data table variable name is (build data)
and i am getting this error.
