How to fetch "xyz" characters <Body>xyz</Body>
I have a file in which I have Body tag. It contains large amount of data. How do I fetch the data between those tags?
Hi @Deepak_M,
You could use regex to do this! See example below of the regex, as well as how it appears in UiPath:
Obviously this is quite rough, and could be refined a bit more nicely (such as using variables for input string, regex string or using .Matches instead if there is more than one body). Use a Write Line to test the output to confirm it is what you want.
Let me know how you go! :slight_smile:
Can you please share your workflow?
This is my sample code. Iwant to fetch data from “reportBytes” tag.
@Deepak_M
You can use Deserialize XML Activity to do this. Please check below thread for your reference.
I am unable to find my root. Can you please tell me in my case what is root element?
@Deepak_M sure here you go:Regextest.xaml (4.5 KB)
You would just need to replace the “Body” tags in the regex to “reportBytes”.
Let me know if you encounter any issues :slight_smile:
Thank you very much @mcicca. You are a savior.
Thank you @lakshman. I got output with regex.
No problems glad I could help @Deepak_M! Do you mind marking my first reply as the solution to your issue? This should help others that come across the same problem to find an answer more easily.
Cheers :slight_smile:
When you are fetching data from mail use the regular expressions
regex.Replace(variableName, “<.*?>”, string.Empty)
dataType:System.Text.RegularExpressions.Regex
