How to Extract unique Alphabets from a string excluding numbers using “Match activity”
Inputstr - THT123
Outputstr -TH
Inputstr - THT123
Outputstr -TH
Hello,
Can you please try this:
System.Text.RegularExpressions.Regex.Match(InputString.ToString,“(?sim)[^\d])+”).Value
Thanks!
Athira
Thanks for the reply Athira. I get the below error
21.10.5+Branch.support-v21.10.Sha.369f46199a0fa6287d86ab2534b6896019db01bc
Source: Message Box
Message: parsing “(?sim)[^\d])+” - Too many )'s.
Exception Type: System.ArgumentException
RemoteException wrapping System.ArgumentException: parsing “(?sim)[^\d])+” - Too many )'s.
at System.Text.RegularExpressions.RegexParser.ScanRegex()
Sorry, there was a small syntax error. Please try this:
System.Text.RegularExpressions.Regex.Match(InputString,“(?sim)[^\d]+”).Value
Thanks!
Thanks Athira ,now i m able to get the alphabets from the string ,however I need to have only the unique alphabets from the string
eg Input str =THHT123
OUTSTR = TH
hey
try with this
System.Text.RegularExpressions.Regex.Replace(test,"\d", " ").Trim
regards!
After getting only the alphabets, can you please try to use this:
String.Join(“”, InputString.Distinct())
Thanks!
@tharani.natarajan Try the below one
(\D)(?!.*\1)
It will give the unique alphabets in an input string. We can concat when we are retrieving using Matches activity
Please find the attached workflow below
Example.zip (2.6 KB)
Hi @tharani.natarajan ,
You could try with the below Alternative as well :
InputStr = "THT123"
Then, Below Expression should give you the Distinct Letters present in the String :
String.Join("",InputStr.Where(Function(x)Not(x.ToString.IsNumeric)).Distinct().ToArray())
Sorry for hijacking but can you explain the code below within the regex.
(?sim)
Ive seen it a few times and now im curious
Thanks
