How to extract string from one column and place in another column
Please help I want to extract the year (last 4 characters from Date column) and place in Year column using UIpath. (Note: They are string values)
I’m trying to achieve this:
Pls help. Thank you.
Hi @gregoryoffodum
Welcome to Community!
Here below the steps to achieve the above!
Step1:Read Range the excel Using workbook activities
Step2 for each row of the read Datatable
Step3:Inside the body Use assign activity
StrArray(VariableType) = Split(CurrentRow(“Date”).toString,"/")
Step4: Assign Currentrow(“Year”)=StrArray(2)
Step5: Outside the body of the Loop write range with the same Read range path and Datatable.
And Please refer to xaml with the skeleton for your process.
Main.xaml (7.1 KB)
Regards
Hi @gregoryoffodum ,
If you want to achieve this with Linq then refer below steps:
1 - Read excel
2 - Use Linq to get year with respective dates
3 - Update in excel with write range.
Test.xaml (7.5 KB)
GetYearDateRows.xlsx (17.4 KB)
Output:
Hi @gregoryoffodum
We can do this in single line code itself
  1. Read the excel and store in dt1(check the preserve format option)
  2. Use invoke code and argument dt1 as in/out
dt1.AsEnumerable().ToList().ForEach(Sub(row) row("Year")= DateTime.ParseExact(row("Date").ToString,"MM/dd/yyyy", System.Globalization.CulturalInfo.InvariantCulture).Year.ToString))
  1. Write the dt1 to excel using write range
Regards
Nived N :robot:
Thanks Calvin. Will try this. The field is already in string. No need for conversion
Hi @gregoryoffodum
Let me know if its work for you!
Regards
Thanks a lot. It does. But on a curious note, if the string were to be “12/2/2019 00:00:00”.
what would the assigned array value be? I’m still interested in the year “2019”
Hi @gregoryoffodum
If we assign the value string array to the date and split based on the / it will
Store based on index
String_Array(0) contains 12
String_Array(1) contains 2
String_Array(2) contains the remaining year with timestamp
To remove the timestamp use the replace condition as below
String_Array(2).Replace(“00:00:00”,’’")
Hope this clears!
Regards
yes it is now, thanks a lot :+1:
Hi @gregoryoffodum
Please mark it as solution and close the thread!
Regards
