Mailbody:
Item numbers are 04/18 mentioned below;
21567890
43256789
1234568907
546789
regard,
abcdef
Mailbody:
21567890
43256789
1234568907
546789
regard,
abcdef
Hello,
you can use the “Matches” activity, which returns all matches of a string. So you can simply set your mail body as input and use the regex editor to find all numbers. Your regex will look like this: (\d+)
Hi, how can I print its output?
Thank you so much
