HI All,
I have a string like this - =ROUND(‘10A’!E77,2)
I need to extract the string after the character ! till next 3 digits. Means in the above string I need
E77 as an output after the string manipulation.
HI All,
Hi @Karan28,
The following will do
System.Text.RegularExpressions.Regex.Match(myString, "(?<=!).+?(?=,)").Value
@Karan28 You might also could try with the Split method to get the value you need:
Split(Split(“=ROUND(‘10A’!E77,2)”,“!”)(1).Trim,“,”)(0).Trim
But there might be errors in cases where the Split Value may not be present, you may need to handle those cases.
Hey , thanks for the solution . It worked for the above mentioned string but giving null value incase of this -=‘9’!E39 string. My ultimate aim is to get 3 character string just after !.
and the main string willl be of any type.
Hey thankyou so much , this worked in all the cases
Hi Sorry for saying late but this manipulation taking the data from ! to the end of the string and I want till 3 characters.
=+‘P&L Notes’!D12+0.0035
for ex, here I want only D12
and your logic is giving me D12+0.0035 as output
@Karan28 If it’s always 3 Character after the ! that you want to extract then you can use this :
Split(“=ROUND(‘10A’!E77,2)”,“!”)(1).Trim.SubString(0,3)
Thankyou so much , it worked
