How to escape double quotes while passing body in api
Hi All …
i would need to pass the below in body for an API .
how do i do this . kindly help
“merchantId”: “AFuH”,
“storeId”: “AF0067”,
“userId”: “Abem”,
“type”: “mailfund”,
“amount”: “20.00”,
“currencyCode”: “GB”,
“clientSystemTransactionId”: “JTTE13”,
“accountDetails”: {
“cardTokenizedNumber”: “991001517”
If you have a VB.net language project, in the HTTP Request activity, the Body should have this format:
""merchantId"": ""AFuH"",
""storeId"": ""AF0067"",
""userId"": ""Abem"",
""type"": ""mailfund"",
""amount"": ""20.00"",
""currencyCode"": ""GB"",
""clientSystemTransactionId"": ""JTTE13"",
""accountDetails"": {""cardTokenizedNumber"": ""991001517""}}"
If you have a C# language project, in the HTTP Request activity, the Body should have this format:
" + "\n" +
      @"""merchantId"": ""AFuH"",
" + "\n" +
      @"""storeId"": ""AF0067"",
" + "\n" +
      @"""userId"": ""Abem"",
" + "\n" +
      @"""type"": ""mailfund"",
" + "\n" +
      @"""amount"": ""20.00"",
" + "\n" +
      @"""currencyCode"": ""GB"",
" + "\n" +
      @"""clientSystemTransactionId"": ""JTTE13"",
" + "\n" +
      @"""accountDetails"": {
" + "\n" +
      @"""cardTokenizedNumber"": ""991001517""
" + "\n" +
" + "\n" +
Let us if this Body is now accepted in Studio.
in VB: defining a JSON string -
we can use the " when escaping double quote
Or we are using single quote instead
grafik
when spanning over multiple lines then we concat the lines like
"{ ""merchantId"": ""AFuH"", " &
" ""storeId"": ""AF0067"", " &
In some cases we prefer to read in the JSON from a text file e.g. when it is used as a template which we want also easy to configure
Hello @tharani.natarajan, :smiley:
The best practice (and easier) to solve this problem is creating a JObject or Dictionary variable, initialize it and build it the way I did in Example.xaml
Note: Then just input the JObject as a String (Json.ToString) in the body of request. Ok? Try it!
print
Example.xaml (9.0 KB)
Thanks
for sort and simple solution
