Hi all,
Is there is any way to enable simulate click to all click activities in UiPath by changing in one place.Rather than changing in each and every activities? . Need a detailed info regarding it .
Thanks in Advance
Hi all,
Thanks in Advance
@Akash_Clv I did not try
but i find some suggested solution
Hi @Akash_Clv
You can try making the changes at the project level, by implementing the changes in the ‘Project Settings’ tab.
You can keep the simulate targeting type by default & it will be applied to all the click activities, unless and until overwritten at the activity level.
Hope this helps,
Best Regards.
Hi @Akash_Clv
Change the Use application\browser activity to Simulate then all of the activities which is inside the use application\browser activity. Then all the click activities are defaulty in same as application\browser option.
Hope it helps!!
Hi @Akash_Clv
While you are using use browser or application in modern experience then change the type to simulate in that particular activity so that what ever the click activities encapsulated in use application or browser all those uses the simulate type.
Regards
