How to design a web scraper using AI solution
I have 300+ URLs to scrap data example production title, description, specification, download images, pdfs if anything, but traditional approach using selectors for each URL is challenging, is there a solution to achieve this using AI solutions.
Hi @RanjitN,
First, create an Agent to scrape data and download documents to a specific folder, then deploy it to Orchestrator. Next, build an RPA workflow in Studio Web, loop through the list of URLs, and call the Agent in each loop.
Hope it helps!
@RanjitN
not in production but you have ui agents which are coming which can help in such tasks
if download are not involved then you can try web reader
cheers
Thanks for the reply, I understand that. but while creating Ai agent we need to use connectors mostly 3rd party gpt or openAI to build scraper, then we can invoke in our workflow. is there anything in build so we can create AI agent using those scraper and invoke.
but is it a free solution to build AI agent we can use inside UiPath? because most of the things i tried asking for subscription token basis.
No, as with most things in UiPath there is a cost, however you might be in luck if this is a one off…
The feature they have for this would be this I think. You could try it out and see if it performs. Normally, when something is in Preview, they waive the costs, so you could perhaps use it for free provided you participate in providing good feedback to the product team?
@Jon_Smith
For that we need to bring and connect our own model
