Hi ,
How to create a TestSet in Orchestrator using Swagger APIs using POST Method?
I need JSON Payload for request body .
Hi ,
Use the Inspect tool from your browser and notice the POST call and analyze it.
Example:
URL: https://cloud.uipath.com/marianplatonov/DefaultTenant/orchestrator_/odata/TestSets
Method: POST
Headers:
Authorization: Bearer + access_token
X-UiPath-Organizationunitid: FOLDER_ID
Accept: application/json
Body of type JSON:
{"Name":"TestSet1","Description":"TestSet1_description","Packages":[{"PackageIdentifier":"TestAutomationProject1","VersionMask":"1.0.*","IncludePrerelease":true}],"TestCases":[{"DefinitionId":34215,"ReleaseId":661512,"VersionNumber":"1.0.114285370","Enabled":true}],"InputArguments":[],"RobotId":994169,"EnableCoverage":true}
Can you try this JSON Payload-
“Name”: “TestSet Name”,
“Description”: “TestSet Description”,
“ReleaseId”: 12345,
“EnvironmentId”: 54321,
“Priority”: “High”,
“CreationTime”: “2023-05-18T10:00:00Z”,
“StartTime”: “2023-05-19T09:00:00Z”,
“EndTime”: “2023-05-19T17:00:00Z”,
“JobsCount”: 10,
“Source”: “Manual”,
“SourceParameters”: {
“Param1”: “Value1”,
“Param2”: “Value2”
Thanks!!
