we are unable to copy one sequence of project to another project which is already saved … is it possible to copy one project anytime whenever we need ?
Ya that’s possible
We can copy a xaml file of one project to another project folder
May I know the issue you were facing
Cheers @bhala
Yah it’s copied actually
The reason is project dependencies compatibility
So click on the original xaml and go to design tab and in that click on manage packages and click on project dependencies tab
Now ensure that same version and same set of packages as installed in the copied xaml project folder
Or
In the current copied xaml click on output panel of studio and check which a activity package is missing and install that in design tab project manager under official tab
Cheers @bhala
ok i’ll try to solve…
thanku sir …for your help
