I need to convert a particular column to upper case using vb.net code
Is it okay to loop all the values in the column and convert them to upper, then replace the values in the data table?
Is there any vb.net code to convert directly
Just record a macro, it will give you the code. You can then use it in Invoke code activity after dynamic changes or you can run the macro whenever required. @raghuram1
yourstring.ToUpper will convert to upper case, please brief your query clearly, while reading you need upper case or where you need to update it with upper case
I need to convert column values in a datatable to upper
while reading that value from that column you can use Convert.ToString(datarow(“ColumnName”)).ToUpper.
But if you want that to be converted within the datatable and saved it to a excel or a database please confirm.
It should be converted within
datatable
