How to connect Power Uipath with Power BI the correct way
Hi friends,
I´m trying to connect Power BI with UiPath Orchestrator.
I have trying to follow these two links
First step
And the this
Second step
But i dont get it to work.
In both these Tutorials they refer to Orchestrator Reference, this page does not exist any more.
Where to finde the correct information?
@Anders_Dahl1
In the new way the api interaction is different it uses external applications …go to admin-> external Applications → Create a new app and then get client id and secret which can be used to authenticate the api
cheers
Thanks @Anil_G,
I will try this. Do you know how i can get the logmessages out from the API. I cant find it in the documentation.
@Anders_Dahl1
You can get them using robot logs…for more info on the endpoint and how to use…you can refer to the swagger file
/swagger/index.html` - this link will take you to the swagger.Please replace with your orchestrator url
Hi @Anil_G
I need your support.
I have now created a External application in Orchestrator.
When i try to use it in my Power BI model i do get any token back.
What can be wrong?
@Anders_Dahl1
Did you first try on postman to check?
Are you using client credentials only?
@Anil_G
Yes. But after you have created an External applications.
Would the next step to add my external app to a tentant?
@Anders_Dahl1
Then next step would be to test on postman to check if you are getting response
If you are getting then in powerbi tenant you can add the auth
@Anil_G
Thanks for the help on the way.
Now i solved the first part. But now there is another issue.
When you get the RobotLogs you wil only recive 1000 rows. This is a problem for me when i have 5000 rows.
Do you have any ide for me to solve that?
@Anders_Dahl1
You hvae pagenation option(skip)…use that in the api and get the next 1000 records and so on
@Anil_G
But then i need to do that manually to switch the number with the skip command. I want it to get all of the data from Orchestrator auto and fill my table in Power BI.
But i have another thought, can i feed a sql data base and store the data there?
Then i can filter on the date as well.
@Anders_Dahl1
I hope this might help you for a way to use skip
Hi, Can you please elaborate on this?
