How to connect mainframe applications PASSPORT PC TO HOST using uipath.
Thanks for quick response
Its TN3270E
Install Uipath.Terminal.Activities Package to Automate MainFrame applications.
Installed, I tried all the available options, still not able to launch mainframe ![]()
Installed, I tried all the available options, still not able to launch mainframe .
Its TN3270E
Ashwin, I tried this still facing error
Uncheck the basic checkbox.
Hi Praveen,
were you able to connect to passport pc to host from ui path. I have same requirements. if you were able to connect, pls reply.
Hi Arvind,
Were you able to connect. I am using the above setting but its not connecting
