I have 3 task based on same file first 2 task need to provide output file …based on thiis output going to do task 3…how to choose itis in which flow…
Thanks…
Thanks…
Hi @nirmalad123
Choosing between a Sequence and a Flowchart in UiPath depends on the complexity and nature of your tasks:
You can use both sequence and Flowchart for this process. But If you have many complexity conditions and branching better to do it in Flowchart.
Hope it helps!!
