How to call Power BI API with Filter or parameter applied using UiPath Http client tool
Hi Team,
we are trying to download Power BI report using API call by using UiPath HttpClient activity.
we are able to export report and download to local folder.
But we are facing issue with applying dynamic report filters. anybody have working example how to get the filtered report.
Thanks in advance for your help.
Thanks and Regards
Ramu T
Well, What i can suggest you is to try using Postman App and do r&d over it.
Postman will simplify parameters that are used for query
