I am building power automate workfloe to trigger an email and update excel in sharepoint and then use powerbi to present the volume fo it. How ca i bring in UiPath in this workflow to value add.
Thanks!
Thanks!
Why would you? Sounds like adding complexity for no reason.
Hi @postwick
I wan to do data cleaning from the sharepoint before presenting it to powerbi
The general aproach would be to either use UiPath or Power automate.
This looks a simple process. What’s the value added you are looking to automate through UiPath which the PA can’t do and if something is there, why not automate everything using UiPath.
Can’t this be done using Power Automate cloud flow ?
Create a cloud flow to clean SharePoint and invoke it in your power automate workflow.
Hi if i wan to use UiPath, can share with me a flow
