Hi All
We are using RE framework. If any system exception happens bot moves to the Init state for retry. But because of that the queue is loaded again and everything in the Init state executes again.
So how to avoid the queue to load again ?
Hi All
Then in init state if u look there is if condition which specify the config is nothing
Config is nothing implies that workflow is running at first time and it set up all config dictionary values so since u want to add queue at first time only , so put the adding queue item section in the then section of that if activity
This is logic I want to tell you
You can modify it Accordingly
Hope it helps
Mark it as solution if it helps you
Regards
Nived N
Happy Automation
Hi @NIVED_NAMBIAR
I got your point. In normal RE framework that condition is there. But the customized framework which we have received from our client there that condition is not there which will specify if it is a first run.
What to do in this case ?
Like while intialising the config section there is if Condition there
Is it there ?
Hi @NIVED_NAMBIAR @ksrinu070184
I understand your point. Let me check with the concerned team about the framework. Then will get back.
