How to auto-train documents using UiPath IXP for unstructured and complex data extraction
Hi ,
I am using UiPath IXP for extracting data from unstructured and complex documents .
I want to understand how auto-training works in IXP:
  1. How can we enable auto-training for documents?
  2. Is there any specific activity required for auto-training in UiPath?
Please guide me on the correct approach and best practices to auto-train documents using IXP.
Thanks in advance for your help.
Regards
Sourav Bhunia
hi @sourav.bhunia
IXP Auto-Training (Generative Extraction):
  1. No specific UiPath activity needed - auto-training happens in IXP web interface
  2. Enable: Create Generative Extraction project → Upload 10-20 samples → Define schema → Write prompt → Auto-predicts
  3. Train: Validate/correct predictions → Refine prompt → Repeat (no ML training required)
  4. Use: Publish model → Call with IXP Extract activity in Studio
Key: Prompt engineering + human validation loop improves accuracy iteratively​
Best Practice: Start with diverse samples, aim for >80% confidence, use Orchestrator queues for production validation.
Regards!
Hi @sourav.bhunia
Pls check:
Happy Automation
Hi @sourav.bhunia
You will find some insights on your usecase,
Please find below youtube video to get more closer information about UiPath DU using UiPath IXP
@sourav.bhunia
There is no training or auto training involved as of now with UiPath IXP
extraction and all depends on the prompts given at document and field levels
cheers
