Hi, I need print Character @ in outlook and Word, i take email of Excel File but need put in the email’s body and uipath not print. Any solution please ??
@juanvillalba92, I think you must be really close. I ran your workflow and got this result:
If you aren’t getting an arroba in either Outlook or Word, I suspect a locale problem, such as maybe your UiPath is in English and your Word and Outlook are set to Spanish. I’m guessing here (since it works for me) but maybe try Alt+64 (or maybe AltGr) on yours) to enter the @ instead of using the arroba on your keyboard. That should set it to @ as long as you’re using codepage 437, maybe elsewhere too. You could try it in your Word and Outlook first.
