Hello everyone!
I need get project that is at ochestrator, but with update of .net i don’t found the xaml or project.json to open at studio to edit my project.
I remeber that before, those file was inside of folder lib/net45.
Can I help me ?
Hello everyone!
Can I help me ?
In the latest windows compatible projects if we do not check the include packages option while publishing the project then you cannot get xaml files from nupkg as before
Hope this helps
Oooooh I didn’t know about it.
Where I check this option? Would you show me this?
Thanks,
Thank you so much. This was what I need.
Have great week.
