Thank you for sharing. However, I try to ran the workflow, it failed due to Part No. in Sheet1 does not exist in Sheet2.
Can you share data which i can run as it is?
Hi YoiChi
sorry for the delay
the data are real so i cannot send out
I fabricate new data sheet and new sequence
now i am stuck at turning “Discount Percentage” to “discount factor” just by divide by 100
the error message i receive is object cannot be cast from DBNull to other types
I am using the same formula as before, i wonder what went wrong
can you advise
Next I will be need to multiply the “discount factor " to “List Price” and QTY to get my “” Total Price”
It’s because Part No of row No.23 or above is blank. (in Main sheet)
If you can delete row No.23 or above, can you try FilterDataTable activity with remove PartNo “is Empty” just before ForEachRow?
