No I couldn’t solve it
Hi @Latoya_mbatha ,
If the Invoke Code
Activity was working in an another Project, and as you have mentioned you have copied the Invoke Code
from one Project to another, it was concluded that it was not working as expected or does it give out any particular error ?
I would also suggest you to Check the Output Panel for any logs that indicates the error message.
We would need to know what was the Error to move forward in correcting the error.
hi i finally found a different approach to fix it. its working really good
thankyou
It would be helpful if you could post the solution or the work around you have found to solve this issue. This would help others with similar issues to solve their problems faster. In turn you could close this topic as well.
i created a process and named invoke code.
in the main workflow
i inserted
the clicked import arguments
