I am trying to delete the parts of array contains “someString”, and all the parts happen to be even number of index. It will also be great if you can provide me the method of how to delete parts of array which contains"keyword".
Thanks for your reply, can you please kindly specify your solution more clearly?
Is this the actual code that I need to add? Where should I add the code? Should I still use for each activity?
use above in assign activity:
MyArray assign (From item In MyArray Select item where Cint(item) Mod 2 <> 0 Order By item Ascending).ToArray
in MyArray you get only odd numbers
