I’ve to make Report name variable available in between the html body … Please help.
Hi MaheshPlease find attached the ***{ReportName}*** Employees Information Report Extraction. Thanks ! Kind Regards, Manish
Refer this
thanks for your reply !
Actually, I’m not using any txt file … I’m directly editing the body with isHtmlBody flag enabled. How to achive it in that case ?
Example
> "these links:<br><a href='"+inputFile+"'></a>."
“inputFile” is the Variable
Not working as it says compiler error :
It got sorted. I don’t know the reason but it only works in a single line. don’t jump on to next line. Thanks !
Yeah it will worked if written in one line and including double quotes for style css also.
