Hi In my Ui Path studio CE addtion Web Scrapping option is not showing.Please help
I am getting “This control does not support extraction” message while using data scrapping as there is no option for web scrapping in ui path community edition
Which browser are you using ?
In case you using chrome then please install chrome extension for uipath .
Please refer below .
https://studio.uipath.com/v2017.1/docs/installing-the-chrome-extension-for-uipath-studio
internet explorer
Did you try with chrome if not then follow up this for IE
What version you are using? and what control you are indication… will you let me know ? @viveksri06
Internet explorer 11 i am using and i am trying to use data scrapping tool…
Hi @viveksri06
Please check if you have minimum the .net framework 4.6 on your machine:
Start menu → Run → regedit.exe
In the registry editor go to: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full
You should be able to see something like this:
now everything is working as expected …thanks
