I am trying to populate a body for a POST, but can’t seem to figure out how to use variables within. I have successfully gotten the POST to work with a static body from a text file, but I want to use variables as it is a dynamic request. Here is what my body looks like where the CaseID and name would be a variables:
“taskId”: 1234,
“data”: [
“index”: 0,
“columnName”: “System”,
“value”: “TEST”
“index”: 1,
“columnName”: “CaseId”,
“value”: “ABC123”
“index”: 2,
“columnName”: “Name”,
“value”: “Smith, John”
“documentItemGuid”: null
Please refer below post. Basically idea is to double the double quotes to be able to pass variables, should look like below where userid is a variable and name has static value.
jsonBody = “{”“id”“: “”” + userID + “”“, ““name””: ““John””}”
simple and direct way would be to use place holders intext and then use replace function
“taskId”: 1234,
“data”: [
“index”: 0,
“value”: “TEST”
“index”: 1,
“value”: “<CASEID>”
“index”: 2,
“value”: “<NAME>”
say the above is assigned to str string variable
str.Replace("<CASEID>",actualcasedID).Replace("<NAME>",actualname)
cheers
Thanks! I realized I was using only 2 quotes instead of 3 between the variables and that’s what was failing.
I am glad it worked ![]()
