I would like to use regex to extract som data from a txt file. But all the data comes as a long string whit no spaces
ValueValueValueValueValue
Say I only want to extract the the string from to . I guess that it´s possible to first insert a space betweeen all >< then use regex patter starts with ends with but how do I first insert?
I have tested, and could print the values in the log but did not manage to build a for each loop so they were saved in different columns in the database.
Also could not extract the text that have special characters (swedish å ä ö)5387.xml (2.5 MB) Zlotzky (1).xaml (9.8 KB)
