I am attaching the xaml project as well as the Excel sheet in this topic.
It runs through the whole process fine, but when it finishes to go to the next row on excel it stops.
It doesn’t seem to continue and loop back to fill in the fields from each row on the excel sheet.
When It reaches the last step the mouse snaps to a section of the page and just stops.
after about 15 seconds an error will pop up: (**20.10.3+Branch.master.Sha.7813e000692e3c2b01e0d34df985b6379a3f1eff
Source: Select Item ‘SELECT’ (Select Item ‘SELECT’)
Message: Cannot select item. It was not found among existing items.
TIP: Some combo-boxes delay load items until its dropdown is expanded. Try to simulate a click on control prior to selecting an item.
Exception Type: UiPath.Core.ElementOperationException
RemoteException wrapping UiPath.Core.ElementOperationException: Cannot select item. It was not found among existing items.
TIP: Some combo-boxes delay load items until its dropdown is expanded. Try to simulate a click on control prior to selecting an item. —> RemoteException wrapping System.Runtime.InteropServices.COMException: Cannot select item. It was not found among existing items.
at UiPath.UiNodeClass.Set(String bstrAttr, Object vValue)
at UiPath.Core.UiElement.Set(String attribute, Object value)
— End of inner exception stack trace —
at UiPath.Core.Activities.ScopeActivity.OnFaulted(NativeActivityFaultContext faultContext, Exception propagatedException, ActivityInstance propagatedFrom)
at System.Activities.Runtime.FaultCallbackWrapper.Invoke(NativeActivityFaultContext faultContext, Exception propagatedException, ActivityInstance propagatedFrom)
at System.Activities.Runtime.FaultCallbackWrapper.FaultWorkItem.Execute(ActivityExecutor executor, BookmarkManager bookmarkManager)
Tes number 2.xaml (37.7 KB)
Copy of challenge.xlsx (34.3 KB)
