Help - Studio freezes at analyzing project when trying to publish
Trying to publish workflow get stuck at Analyzing project. It seems to only be this project that freezes everything else works fine. Im not getting any error or anything. Anyone have this happen before?
Iv cleared cache, reinstalled, restarted…
Hi @Azarill
Check whether you have lot of files in your project folder, if yes, it will check the whole project folder and publish the package. try removing the unwanted files, xaml, folders which are not required and try to remove unused variables by clicking Remove Unused. This should help you publish the package.
Hope it helps!!
Hi @Azarill
Try by update the packages version to the highest andof the runtime rule as lowest as applicable.and also make the testing dependency to one version low.
Hope it helps!!
Thank you for the responses! I tried doing both things with no luck.
@Azarill
Just to check try to disable the workflow analyzer rules and then run
Home-> settings → disable
@Azarill,
Try resetting the Studio settings and restart the studio once.
Thanks,
Ashok :slight_smile:
Just wait. It will finish eventually.
If you’re working across the network (ie the project is stored on a network share) then it slows things down. VPN is even worse.
