See text below. I need to break this string into 3 groups each starting with CHAIN: because each group pertains to a different reporting division and dates. Thoughts? This is in a datatable in Studio.
Column1
CHAIN: ODS390-001 DUMMY COMPANY WIRE DATE: 04/11/23
“04/11 02:32 04/11 POS 1,858,080.72 VISA & MASTERCARD 1,602,745.01”
04/10 06:32 04/10 POS 839.62 VISA & MASTERCARD 829.62
“CARD FEES 28,003.59 DB”
BILLING SYSTEM FEES: .00 DB
NET CHARGEBACKS: 336.76 CR
PROCESSING ADJUSTMENTS: .00 DB
CHAIN: ODS390-002 DUMMYCOMPANY WIRE DATE: 04/11/23
“04/10 22:49 04/10 EMD 840,764.18 VISA & MASTERCARD 817,939.83”
CHAIN: 0DS5390-002 DUMMY COMPANY WIRE DATE: 04/11/23
“CARD FEES 14,118.07 DB”
“NET CHARGEBACKS: 3,626.40 CR”
PROCESSING ADJUSTMENTS : .00 DB
CHAIN: ODS390-004 DUMMY COMPANY WIRE DATE: 04/11/23
“04/11 00:34 04/11 POS 3,498.27 VISA & MASTERCARD 1,628.69”
“04/11 02:32 04/11 POS 28,216.17 VISA & MASTERCARD 19,174.75”
CARD FEES 342.89 DB
NET CHARGEBACKS: .00 DB
CHAIN: ODS390 DUMMY COMPANY WIRE DATE: 04/11/23
Thanks my friend. I tried this already but that only gives me the lines starting with CHAIN: I am trying to segment the groups that sit between each CHAIN: key word into different blocks of text. I appreciate the idea though.
if I split on CHAIN: it will give me what is after “CHAIN” but only on the same line. It does not give me the next row of data. What I am attempting to do now is count how many times I find a key word, putting that to an array of Int and then looping through that array of int to split the text into group parts. Since I do not know how many times this new key word will appear in any given document, I created a counter beginning at 1 and in a do while I am splitting, looking for the data I need and then increasing a counter on the split until it reaches the counter for the number of times the word is found. It is just really code heavy which I do not like. If anyone has any other ideas hit me up
the pdf is a highly structured pdf that I had to read with Tessaract OCR to get it into one string. There are potentially over 200 + lines that I ingest into the code. I do not want to write an append for each line. I am looking to group the data between the Key Word CHAIN: which seems to be a break in the data sets. Hope that helps understandng
