Hi All,
I am pretty new for RPA- UI Path need help with one of the scenario which we are trying as part of data sanity checks.
Scenario:-
I have created an existing odbc connection to connect with teradata to execute few sql’s. Once the sql’s gets executed need to capture the output of the queries in attachments.
Send an email to the user with some message ‘These are the date trends for this week’ by including the attachments.
Problems:-
I am encountering few problems say if the data base gets timeout then the process is failing with that error instead i want to introduce an exception where in it should go in a loop till the connection is established and then execute the query how to achieve this.
Attached is the XML file which I am using for reference.Main.xaml (35.7 KB)
How can i integrate Informatica ETL and BMC - Control M with UI path – This we can discuss further in detail if any one is interested to help
