Help!help!help!
In the uipath process, you need to traverse the list in the red box and use the values to the following activities in turn. However, after setting the process as shown in the figure, you can only cycle to the first value. Who can give me some advice?
Partial screen shot of your for each makes it difficult to ascertain why your loop maybe exiting after the first value.
Do you have some logic in the Excel container that is causing the loop to break?
