I am attempting to use a Read Cell activity within GSuite Application Scope to read a cell from a Google Sheet and use the output of that cell as the StartingCell for a Write Range activity. The cell referenced within my Read Cell activity contains a formula, but the text reads, “A141” (with the double quotes, to be used as a cell reference) for example. I want to use that output as the StartingCell for my Write Range, so that I don’t have to manually update the starting point each time I run my Sequence.
Here is what I’m trying to do, where “spreadsheetID” is the Google SheetID, sheetIDListofONLC is the name of the tab within the Google Sheet, ONLCircles is the data that is to be written, and Testing2 is the cell reference (“A141” as mentioned above).
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
