getting system is busy while running any process thro’ CONTROL room
When designing a workflow, use kill applications in the beginning for the applications you are dealing in the workflow. This will ensure that processes are released even before the robot starts executing them and eliminate the chances of “system is busy” error.
Additionally, you need to ensure , at a time one robot can can be executed in a system. so ensure there is no overlapping schedule.
Thanks,
Tuhin
